67 battery heat shield correct finish is? - NCRS Discussion Boards
  • Phil P.
    • April 1, 2006
    • 409
    i purchased a battery tray kit from paragon and the heat shield appears to be "gold" or yellow diechromate zinc,is this the correct finish or should it be black---thanks for any inputs,phil
  • Gary B.
    • February 1, 1997
    • 7035
    Phil,
    I assume '67 is like '66, in which case it should be black.
    Gary
    • Paul L.
      • November 1, 2002
      • 1414
      Re: 67 battery heat shield correct finish is?
      The Judging Manual says:
      "This shield is stamped steel painted semi-gloss black".
      • Keith M.
        • November 1, 1976
        • 205
        Send it back and order one from Long Island.
        • Gerard F.
          • June 30, 2004
          • 3806
          Phil,
          Just paint it semi-flat black, Krylon 1613 (#?).
          Jerry Fuccillo
          #42179
          Jerry Fuccillo
          • Phil P.
            • April 1, 2006
            • 409
            hot up there jerry? i did just that yesterday afternoon,the paint dried as it came out of the can it was so hot,figured i would keep it as it has some extra corrosion protection,thanks to all ,phil
            • Gerard F.
              • June 30, 2004
              • 3806
              Geez, it's hot in N. CA
              Phil,
              At 9 PM last night when I responded to your post, it was 92 on my deck thermo, coming down from about 105 during the day here in Sonora. Forecast for today is for a little relief down to 100. Boy, this past week has been misery.
              But I guess it has been hot all over the country, especially in the SW. Will be glad to take a week off to Boston.
              How hot is it, guys? What's the forecast for Boston, the end of this month?
              Jerry Fuccillo
              #42179
              Jerry Fuccillo
              • Paul L.
                • November 1, 2002
                • 1414
                Re: Geez, it's hot in N. CA
                Jerry,
                It's now 65F here in Ontario, Canada.
