'66 rear license lens gasket question - NCRS Discussion Boards
  • R N.
    • May 31, 2002
    • 640
    Hello All,
    I have a question regarding the rear license lens gasket. Paragon has one that is dark grey in color and Doc has dark grey and white in color listed.
    The judging manual says should be white and I just want to be sure which is correct, white or the dark colored one.
    As always, thank you for your help in advance.
    Best regards,
    Kurt
  • Tim E.
    • April 1, 1993
    • 360
    Re: '66 rear license lens gasket question
    My June car is white. Here's a photo of the original:
    • John D.
      • December 1, 1979
      • 5507
      Kurt, As Tim stated they are white. Chevy used to sell a replacement license lite assembly and it typically came with a gray gasket. That's where all the gray vs white stuff came from over the years. John
      • Keith M.
        • November 1, 1976
        • 205
        White is what I have seen over the years. If you get any color other than white a spray can of white paint will fix it. Just let it dry real good before you install the lense.KM
