67 427 dipstick - NCRS Discussion Boards
67 427 dipstick
  • Phil P.
    • April 1, 2006
    • 409
    67 427 dipstick
    put my motor together and i think i have the wrong dipstick and tube---here is what i have---p/n 3981088 use se engine oil is on the flat blade, which has a length of 24", the handel has a salmon button and a dimple--this configuration looks to be too long but measures correctly---thanks for all inputs
  • Richard F.
    • May 31, 1986
    • 193
    Re: 67 427 dipstick
    Phil, Trying a search on the part number. This has all been obsessed on before. The 3981088 definitely did not come on your car from the factory. The correct tube should only extend about two inches above the tab that bolts onto the exhaust manifold. The 3981089, which goes with the 3981088 tube is several inches taller than that.
    • Phil P.
      • April 1, 2006
      • 409
      Re: 67 427 dipstick
      thanks richard---i kinda figured it was wrong, but it sure is easier to work with when checking the oil---thanks again,phil
        • 43221
        Re: 67 427 dipstick
        PHIL-----
        If you use the GM #3981089 dipstick tube with the GM #3981088 dipstick, you will get a correct reading with any Corvette big block oil pan. However, this combination is not "correct" for your application. If you want a more-or-less "correct" set-up, they are available in reproduction, although they may lack some nuances of original configuration. If all you want is a functional set-up and you have the above parts, you have what you need.
        • Phil P.
          • April 1, 2006
          • 409
          Re: 67 427 dipstick
          joe,thankyou,--what does my existing configuration fit ? as i might as well sell it on ebay to re-coup the cost of a replacement---thanks,phil
            • 43221
            Re: 67 427 dipstick
            PHIL------
            The combination you have was originally used for 1970-74 Corvettes with big block and later became SERVICE for earlier Corvettes.
