Finally got to measure the vacuum on the L79 with the rattling PCV valve today. Had only a little time, and the line to the vacuum advance fit the gauge, so that's where it got measured. This is probably "ported vacuum," so not the best place. Anyway, here are the results: At idle, 8-9 inches. At ~1500RPM, 14 inches. This seems like it should be adequate to pull the valve.
I have a new theory. Something is wrong with the breather mechanism that connects into the air cleaner. There is a canister in the lifter valley that I believe is connected to the breather (didn't assemble myself, but saw the stuff apart). Anyway, have any of you seen the breather assembly put together wrong before in a way that leads to pulsating pressure on the crankcase side of the PCV?
- Wayne
- Wayne
