Chassis Detail Kit 1973 - NCRS Discussion Boards
  • Ralph A.
    • May 31, 2002
    • 236
    Has anyone seen a detail kit avaiable for 1973?
    There are several sources for 72 and older.
    Ralph Adams
    NCRS: 38137 LA: 112
    Slidell, LA 70461
    1969 350/300 LeMans Blue Conv (restoring)
    1971 350/270 Bridgehampton Blue Conv (top flight)
    1972 350/200 War Bonnet Yellow Conv (restoring)
    2001 Bowling Green Metallic Conv (fun car)
  • Steve L.
    • June 30, 2001
    • 763
    Re: Chassis Detail Kit 1973
    I've been wondering this myself but I guess there is no response. Usually means no one knows.
    Steve L
    73 coupe since new
    Steve L
    73 coupe since new
    Capital Corvette Club
    Ottawa, Canada
    • Chuck S.
      • April 1, 1992
      • 4668
      Steve, the only advantage of the "chassis detailing kits" is that they collect more than enough materials to restore markings that you find on your car, and charge you high prices for the basket. If you depend on one of these kits to tell you WHAT MARKINGS should be on your chassis, they are much less useful for that purpose in my opinion.
      Attempting to place markings on your car that are described by instructions in one of these kits is (1) less than honest, and (2) inaccurate in most cases. The instruction sheet may describe a single car, or even if it's several cars, it's still not YOUR car.
      If you find faint shim markings written in white lumber crayon, then buy yourself a white lumber crayon and replicate the marks; if you find lavender paint smeared on a spindle, then buy the small bottle of lavender paint (it's sold separately) and get after it...in either case, replication should be during a restoration when the original marks will be lost. In my opinion, most of the stuff in these kits won't fit your car, and ends up un-used.
      If you don't find any marks, then I suppose that simulating the marks would be better than nothing, but it can backfire on you; e.g. mount has no shims...is the appropriate mark a zero("OH"), or...nothing (judges know the answer depending on the model year). But...putting ALL the possible markings, paint daubs, etc. described in those instruction sheet will be a mistake because ALL the cars didn't get ALL the marks.
      And, no, I don't know if there is a chassis detail kit for a 73, but if I was naive enough to think I needed one, I would buy a 72 kit...the guys building the 73s were the same ones building the 72s, and they went to work the first day of 73 production just like they did the last day of 72 production. These chassis markings had a meaning to the guys building these cars, and MOST LIKELY, they still meant the same thing on the first day of 73 production that they did in 72.
      • Harmon C.
        • August 31, 1994
        • 3228
        Steve
        I have the frame numbers I got off some 73 frames and I think they are correct but they were hard to read. This is what I think they are.
        330960-150 Four speed frame
        330970-100 Automatic frame
        3921675 Driveshaft number
        For the body shims all I have seen is white vertical marks for the number of shims.
        Lyle
        Lyle
