1961 horn ground - NCRS Discussion Boards
1961 horn ground
  • Gary A.
    • May 31, 2001
    • 165
    1961 horn ground
    I cannot get a proper ground to the drivers horn in the correct location. Is it possible to ground to the radiator support without any adverse consequences. Gary
  • Jack H.
    • April 1, 1990
    • 9906
    Re: 1961 horn ground
    Two of the 'typical' reasons for faulty grounding are:
    (1) Having chassis and/or core support components powder coated (thick/heavy compared to factory orignal paper-thin paint) and NOT properly masking bolt hole interconnnect location to preserve bare metal.
    (2) Incorrect mount of horn(s) with improper assy sequence of mounting bolt, horn ground wire ring and washer and/or the washer being worn, not sharp enough/thick enough to bite through the paint on the horn bracket to get a solid electrical contact.
