C2--Change from "quick" to standard steering" - NCRS Discussion Boards
  • Richard W.
    • June 30, 2000
    • 84
    Currently my SWC is set up with quick steering. I aligned it up a couple of years ago when I rebuild the front end. Would I need to realign the front end if I wanted to use the standard setting?
    Dick
  • Tracy C.
    • July 31, 2003
    • 2739
    Re: C2--Change from "quick" to standard steering"
    nope...
    • Richard W.
      • June 30, 2000
      • 84
      I like your style. Quick (2 minutes), short, and to the point. Thanks.
      Dick
        I believe you will, but only the toe-in; - the front and rear holes in the steering arm are not equidistant from the car's centerline; when you change your tie rod ends from one pair of holes to the other pair, it will change the toe-in.
        • Dennis C.
          NCRS Past Judging Chairman
          • January 1, 1984
          • 2409
          John H., as usual, is correct, no free lunch. DC *NM*
          • Tracy C.
            • July 31, 2003
            • 2739
            Didn't realize that John. Thanks for the correction.
            tc
            • Richard W.
              • June 30, 2000
              • 84
              Thanks to all for correction. Have a save 4th.
              Dick
                • 15692
                No effect on caster and camber, but when you change tie rod locations, it DEFINITE effects the toe-in, which MUST be checked and reset anytime you switch from the fast to standard overall ratio or vice versa.
                • Allan J. Wicklund
                  I seem to remember a post that said "All" P/S equiped cars used the Quick steering? Is this so? Thanks, Al W.
                    Al -
                    Yes, that's correct - the factory placed the tie rod ends in the "fast" (closest to the spindle) set of tie rod holes in the steering arms, and installed an aluminum rivet in the "standard" holes so the owner couldn't move the tie rod ends back to that position. If you put the tie rod ends on a power steering car in the "standard" holes, it can allow the power cylinder to over-travel and damage the rod seals.
                    • Gerard F.
                      • June 30, 2004
                      • 3806
                      Don't try it , if you have power steering
                      You will be all over the road at high speed. Guess how I know!
                      The forward lug on the spindle is for power steering, the rear lug is for manual. If you have manual steering and are on the forward lug, you will have already pulled your shoulder in parking the sucker.
                      Jerry Fuccillo
                      #42179
                      Jerry Fuccillo
                      • Allan J. Wicklund
                        Anyone have a photo of the Rivey John describes? I converted my 67 coupe to P/S and would be interested in seeing what's missing. Thanks, Al W. awicklu@optonline.net
                          Alan -
                          LICS has the aluminum rivets (their #49-58); shown in your Assembly Manual in section N40, Sheet A3, item #9. Install them with the head down (not with the head up as shown in the illustration) and the peened end up; the frame was upside-down when they were installed.
