C 1 fuses and instrument bulbs - NCRS Discussion Boards
  • Charles C.
    • May 31, 1978
    • 65
    On the C-1 (1961 in my case), some of the slots on the fuse block have different amps values printed on the opposite ends where the fuses are inserted. In other words, as to the receiving slot for the next to the bottom, right side fuse, the block has 10 amps printed on the left and 20 amps printed on the right. What size fuse goes in this slot?
    Regarding the bulbs for the instruments, what size bulbs should be used or where is this info found.
    Many thanks.
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Owner's Manual - Good place to start... *NM*
    • Howard M.
      • June 30, 2000
      • 124
      Re: C 1 fuses and instrument bulbs
      The fuse and bulb requirements are listed in the Specifications section of the 1953-1962 Corvette Servicing Guide (ST-12) under chassis electrical.
