C-2 differential date code - NCRS Discussion Boards
  • Willard M.
    • August 31, 1979
    • 422
    I have an extra rear end that came with my 64 which was built in Jan./64. The stamping is CE12 19 63 which I take to be 4:11 made on Dec. 19,1963. Is this correct?
    Bill #2659
  • Harry Sadlock
    Re: C-2 differential date code
    4.11 posi it is, but what gears are really on the inside? Pull the cover and take a look.
    • Willard M.
      • August 31, 1979
      • 422
      Old Bubba trick is simply to turn yoke at drive shaft and count. I got a little more than 4 which is probably 4:11 as there doesn't seem to be a 4:13 or 4:14 in the General's usual offerings. It's really the numbers that present some puzzle.
      Bill #2659
      • Tom H.
        • December 1, 1993
        • 3440
        Your reading of the date sounds correct to me, unless I'm missing something here.
        Tom Hendricks
        Proud Member NCRS #23758
        NCM Founding Member # 1143
        • Willard M.
          • August 31, 1979
          • 422
          Thanks for the confirmation. I have just moved from the land of tri-powers(54's did have three) back to FI cars and I have lost touch with what I thought I used to know. Maybe it comes with those many birthdays.
          Bill #2659
          • Joseph T.
            • April 30, 1976
            • 2074
            Bill
            Do you know a Psychologist in Maine by the name of Seth Williams?
            • Willard M.
              • August 31, 1979
              • 422
              I thought that I knew all of the other psychologists in this small state, but that name is unfamiliar.
              Bill #2659
