Clutch Replacement - NCRS Discussion Boards
Clutch Replacement
  • Thomas S.
    Infrequent User
    • February 1, 2000
    • 28
    Clutch Replacement
    The clutch in my 1966 4-speed 350HP finally gave up the ghost this past week. While I have the transmission out and bell housing off, I want to replace the clutch, pressure plate and throwout bearing. I am also contemplating replacing the flywheel with an aluminum one. Does anyone have any suggestions on where to go to get these replacement parts and any experience/ recommendations on putting in an aluminum flywheel? I have heard that putting in an aluminum flywheel can make the car less "streetable." Thanks.
    Tom
    • 43221
    Re: Clutch Replacement
    Tom-----
    Your best bet for a stock replacement is going to a LUK/Sachs unit. You can get these as a complete kit which includes matched pressure plate assembly, friction disc, and release bearing. I would still have the unit precision-balanced before installing, though.
    You can purchase these either in LUK packaging from various automotive suppliers or, even, in AC-Delco branded packaging from Delco parts sources. You get the same parts either way. These units are OEM quality.
    I would forget about an aluminum flywheel. For street operation, all the features of it are a big NEGATIVE for you. A standard weight, stock-type 12-3/4" flywheel is what will do the best for you.
    • Jean C.
      • June 30, 2003
      • 688
      Tom,
      You may want to search the archives for a posting by Tim Bond on the subject of clutch replacement. Tim wrote a very informative "lessons learned" article after replacing the clutch and associated hardware in his mid-year Corvette. Good luck with your task.
      Best regards,
      Charlie
      • Verle R.
        • March 1, 1989
        • 1163
        While the assembly is out, it is probably a good idea to balance the flywheel and pressure plate.
        Verle
        • Thomas S.
          Infrequent User
          • February 1, 2000
          • 28
          Joe, Charlie and Verle:
          Thank you for your responses and help. I am going to stick with a standard replacement vice aluminum.
          Tom
