distributor contact plate - NCRS Discussion Boards
  • Timothy B.
    • April 30, 1983
    • 5186
    Is there supposed to be a felt washer inside the distributor breaker plate where the weight base cam spins. I am aware of the felt underneith to lube the plate when moving from vacuum advance and I thought I remember seeing something like this at the other location mentioned but most distributors don't have them for some reason. Thanks as always, Tim
    • 15674
    Re: distributor contact plate
    Assuming you're talking about the single point distributor the answer is no.
