C3 Headlight actuator support - NCRS Discussion Boards
  • Jeff A.
    • December 1, 2001
    • 95
    Have a broken front mount (ear) on the LH headlamp actuator support PN 3915681-2. Is this part the same fro LH & RH. Is it the same part from 68- ? Thanks Jeff
    • 43221
    Re: C3 Headlight actuator support
    Jeff-----
    The 68+ headlight supports are side-specific. However, I believe that you can use one from any 68-74; it doesn't need to be a 1968. The GM parts are discontinued, but I think these can be had in reproduction.
    Also, these pieces are cast aluminum. It may be possible to weld-repair the one you have. However, I'm sure it would need to be removed from the car for a repair.
