Mid-Year Rearend Date - NCRS Discussion Boards
  • Jim Damasiewicz
    What is an acceptable interval for rearend dates. My car was built around 12/17/65.
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: Mid-Year Rearend Date
    Jim --- Assuming you're referring to the assembly date and ratio code stamping, found on the bottom flange of the case (where it bolts to the rear cover), I'd say 2 to 3 weeks advance on final car assy, more if ratio is one of the less popular, possibly more if your 12/17/65 date is the trim tag code of an A-body car. The case CASTING date could be up to 2+ months prior to assembly. It is doubtful that the rear cover (to which the spring bolts) has a casting date (would be located near the flange next to the filler plug, if it had one). If your rear is a known original, I'd be interested in knowing if your rear cover has a cast part # 3830303 or 3871375 (upside down, at the flange where it bolts to the frame crossmember).
    • Kenneth S.
      • July 31, 1981
      • 302
      My '63 was built April 17th, give or take a day and my rearend is dated April 8th.
      • Mark J.
        • March 1, 1996
        • 254
        Jim,
        My '66 was built approximately on April 5. The date stamp on my engine, transmission, and rear end are all May 23.
        Mark
        • Mark J.
          • March 1, 1996
          • 254
          Re: Brain Fade
          That would be MARCH 23, not MAY 23. Sorry.
          Mark
          • Jim Damasiewicz
            The code on my rear-end is FB 11/22/65, could this be my original rear-end with my build date around 12/17/65?
            • Wayne M.
              • March 1, 1980
              • 6414
              Jim --- No problem with 3+ weeks between your diff and car build; note that Ken posted a 1 week spread. Mark's dates are a little shy of 2 weeks, and I must admit a little brain fade myself; should have said that, for A.O.Smith bodied cars, if referring to build date from the trim tag, the span between diff assembly [or any other S.Louis installed component], can be SHORTER than for an S-body car, even to the extent that the A-body was assembled BEFORE the mechanical components.
              • Robert C.
                • December 1, 1993
                • 1153
                Jim, FYI, Rear end differential codes and dates are not judged in the NCRS.To hard to see! But yours is fine for your build date.
                Texas Chapter NCRS
