Part Numbers Needed:1961 Tie Rod Tubes - NCRS Discussion Boards
  • Mike B.
    • November 1, 2004
    • 389
    Both of my tie rod tubes are bent. Before I schedule an alignment I want to replace them. Can someone (Joe?) please provide the current part numbers? Are they still available from GM?
    Thank you.
  • Mike M.
    • April 1, 2007
    • 60
    Re: Part Numbers Needed:1961 Tie Rod Tubes
    This part is officially called a sleeve, the part # is 3691181, I don't know if it is still available from GM.
    • Mike B.
      • November 1, 2004
      • 389
      Thanks for the reply. I tried that same number based on a reprint of an original parts book and came up empty with GM Parts Direct. Perhaps it was superceeded. I believe that part was used on many old Chevys in the day so I am hopeful that a good quality replacement is still available.
      Any other suggestions are welcome.
      • Dennis C.
        NCRS Past Judging Chairman
        • January 1, 1984
        • 2409
        Mike, Send me an email... Best, Dennis *NM*
          • 43205
          Mike-----
          GM #3691181 is what it was. It was discontinued without supercession in December, 1974. So, it's been over 32 years since you could buy it from GM.
