Re: Can't see cast # - NCRS Discussion Boards
  • bill
    My 70 has a heat shield between the carb and manifold. If the casting number is near the carb flange, I can't see it. The manifold does have the letter P stamped on it near the drivers side front of the manifold next to the thermostat housing.
    • 15616
    Re: Can't see cast # *TL*
    Bill,
    If you really want to know what the application is for your intake you will have to take off that heat shield and look for the casting number. It will be in the areas Joe described.
