C2 poly a-arm bushings - NCRS Discussion Boards
  • Howard M.
    • June 30, 2000
    • 124
    Just checked my records and discovered that polyurethane bushings were installed in both the upper and lower front a-arms in 1993 in my '67.
    Can someone tell me what the bolt torque should be? It's probably time to check it.
  • Andy #28359
    Re: C2 poly a-arm bushings
    Howard,
    The instructions that came with mine say "torque to factory specs".
    • Mike G.
      • January 1, 1991
      • 418
      We would encourage all mid-year owners to spend the $20 on an Assy. Instruction Manual, which has all kinds of useful information --like the torque values for your A-arm bushings. Even gives you the helpful hint to have the wheels on the ground when torquing.
      If you've never done it, it's not a bad idea to retorque ALL your suspension fasteners.
        Lower bushing bolts are 45-55 ft-lbs., uppers are 30-35 ft-lbs. with OEM rubber bushings; have no idea what they are with poly bushings - do they have inner sleeves?
        • Bill S.
          • January 31, 2007
          • 396
          should they have anti sieze?
          i posted earlier this week mine were all but backed out and one gone. i pulled one just now to go to the hard ware store for a temporary one till i can order a replacment and noticed a generous amont of anti seize. this does not make sence to me and may be why they backed out. any ideas?
            • 43237
            Re: should they have anti sieze?
            bill-----
            First, are the bushings you had installed polyurethane type? Second, what has "pulled out"-----the outer shell of the bushing from the control arm OR the elastomer component from the outer shell?
            • Bill S.
              • January 31, 2007
              • 396
              they are poly A frame bushings and it is the bolts that backed out, one all the way.
              • Howard M.
                • June 30, 2000
                • 124
                Thanks to all:
                Yes, the bushings have inner sleeves. Therefore I would suspect that the bushing bolt torque would be the same for poly as for rubber. I wonder if the use of threadlocker might be in order for this application. anyway,
                the car goes on the lift tomorrow to check all the suspension bolts!
                  • 43237
                  bill-----
                  The bolts are threaded into the control arm shafts. I do not understand how the bushings, whether original or polyurethane, would affect the retention of the bolts, assuming that they were installed with the suspension loaded and correct torque to begin with. I would clean off any anti-seize compound from the threads (both bolt and shaft threads) and re-install the bolts using medium strength thread locking compound.
                  • Wayne W.
                    • April 30, 1982
                    • 3605
                    How it does is not of concern, but fact is, they will fall out like a bad set of teeth, so use thread lock, and poly-grip if necessary, to keep them in.
