C2 (1967) - C3 (1968) Span of Use 427 3916321 - NCRS Discussion Boards
  • Tom D.
    • September 30, 1981
    • 2135
    427 Cast 3916321
    I found one in a 66 Coupe. Block came from a Police car, according to the stamped numbers. It's cast date is L187
    1967 Technical Information Manual and Judging Guide says "possible on approximately the last 100 cars" *. Anybody know what's in the "last Stingray"?
    Also. how far into 1968 this block was used? Colvin's book says before January, or in January, 1968.
    *I don't have a later JG, and wonder if similar words are in (for the 1968)...
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
  • Kevin M.
    • November 1, 2000
    • 1271
    Re: C2 (1967) - C3 (1968) Span of Use 427 3916321
    A restamped NOM.
    Kevin
    • Tom D.
      • 2135
      Thanks Kevin, but which casting was used?
      Tom D.
      Michigan Chapter
      Tom Dingman
      • Henry J.
        • November 1, 1999
        • 457
        Tom:
        I wondered this myself. I have a personal e-mail communication from a member who frequents this board and who owns a late February 68 built car (435 HP I believe) with an original 321 block.
        • Mark #28455
          I had an original block from a March '68 400 HP engine, it was a 439 casting. It did NOT have the dowel pin holes drilled for mounting the front timing cover, but DID have the cast-in bosses for them.
          Mark
          • Gregory M.
            • May 31, 1984
            • 178
