Bronze bearing installation in head light motors - NCRS Discussion Boards
  • Keith M.
    • November 1, 1976
    • 205
    Any of you guys know an easy way to put the brass bearing back in my head light motor?
  • Tim E.
    • April 1, 1993
    • 360
    Re: Bronze bearing installation in head light moto
    I had to invent this tool which is similar to a mini-press. I would draw down the wing nuts to apply just a little pressure on the bushing then with a small screwdriver spread each of the retainer ears a little to slowly work the bushing back into place. I repeated this about 20 times and the bushing reseated. Work in tiny increments.
    • John M.
      • January 1, 1999
      • 1553
      Keith, I just replace the retainer with a new one. The original is just lightly spot-welded in place, and it pretty easy to remove. I use epoxy to glue the new retainer in place and clamp it with a deep socket to hold it place while the epoxy sets.
      I am now very careful about cleaning the shaft off before trying to remove the armature. I have accidentally pulled the bearing out in the past because there was rust and crud on the shaft which kept the shaft from going through the bearing, and made the bearing pull out of the retainer. I now only remove the bearing if it is truly worn out, and that is seldom!
      Regards, John McGraw.
      • Keith M.
        • November 1, 1976
        • 205
        Tim,I woul like to talk to you about your press. As I see it there are a couple of steps I may not understand. If you do not mind sharing your phone number so I can give you a call to talk me through your procress I would appreciate it. If you want to you can email your phone number to me at kmajure@bellsouth.net. Thanks
        • Keith M.
          • November 1, 1976
          • 205
          John how long do you think the epoxy will hold? In other words how much are you using the headlight after the repair? I drive this Vette a good bit and I am concerned about durability of the epoxy. Are you applying the epoxy in spots or all around the retainer? Thanks.
          • John M.
            • January 1, 1999
            • 1553
            Keith,
            I would expect that the epoxy will hold as long as the motor housing does not rust away. I cover the entire flange of the retainer with epoxy, and clamp it overnight while it cures.
            • Keith M.
              • November 1, 1976
              • 205
              Thanks John.
