63 340-360 HP bolt survey - NCRS Discussion Boards
  • John D.
    • December 1, 1979
    • 5507
    63 Corvette HHP harmonic balancer bolt. If you are sure that your car has the orignal bolt holding the balancer onto the crank could you please tell us if it has the hole in it. Also tell us what kind of star washer you have. Inside or outside. Should be inside star washer on 63 Corvette. Typically the majority of these bolts are TR in 63. But there may be other companies. Over the counter replacments were LE's. They had the holes for sure. Thanks very much, John
  • Collin MacDonald
    Re: 63 340-360 HP bolt survey
    John,
    Mine is original and its a TR with no hole.
    Hope this helps.
    Collin
    • Collin MacDonald
      Sorry about that previous post it does have a small hole it was off to the side and I could not see it...checked again with flash light...got to go to work now...Collin
      • Rick A.
        • July 31, 2002
        • 2147
        JD,
        will check mine when I get home this evening
        Rick Aleshire
        2016 Ebony C7R Z06 "ROSA"
