61 Powerglide relay - NCRS Discussion Boards
61 Powerglide relay
  • Norman S.
    • September 30, 2002
    • 69
    61 Powerglide relay
    1. Can anyone tell me why the powerglide relay on a 1961 is different than on a 59-60 and 62?
    2. What makes the 61 Corvette PG relay different from a regular horn relay or light relay?
    3. Is there anybody out there that can successfully rebuild my relay? It is an aftermarket unit-- maker unknown-- has number "1335" on its side and "12v" on the top. -- 3 connectors, Left for wire from neutral safety switch, center for ignition switch and right for ground to solenoid. Anyone recognize this number?
    4. Does anyone have a good number for a new replacement switch?
    Appreciate any help you can provide.
    Norm Shier
    Bethel Island, CA
    510-703-1620
  • Norman S.
    • 69
    Re: 61 Powerglide relay Part #
    Original GM Part Number is "1116904 Relay Assy".
    Does anyone have an old, original 60's/early 70's Echlin or other electrical catalog that might show a crossover number. Tried current NAPA but they couldn't turn up anything.
    Norm
    • Mike E.
      • February 28, 1975
      • 5139
      Norm--
      The powerglide relays that I have seen for 61 (and earlier) have 904 stamped into the face of the mounting flange--which is the abbrevieated part number. I'm not sure what you have, as per your first post.
      • Norman S.
        • 69
        Thanks, Mike.
        Mine is an aftermarket and doesn't look like the one in the 1961 CAM on Page A210. My configuration is just like a normal horn relay.
        Norm
        • Gary O.
          • December 1, 2004
          • 4
          62 powerglide doesn't have a relay. I have a relay that is supposed to fit 58-61. It is a replacement for a #1116904, it has four terminals instead of three, but it has instructions for a 3 wire setup. You can have it if you think you can use it.
