69 vette Delco remy horn's ?? - NCRS Discussion Boards
  • Frank Bernier
    Hi guys
    iam at the point to restore my horns on my 69 vette project ... and just found out they are not even vette's horn
    is there anyone out there knows where or who can supply
    original "DELCO REMY" dated horns for vette's ?
    9000245
    9000246
    Thanks Frank
    • 43221
    Re: 69 vette Delco remy horn's ??
    Frank-----
    I think about the only way is to find a used set with the correct numbers and dates and have them rebuilt. You might call someone like Dennis Portka who rebuilds these horns and see if he has any that suit your needs for sale on an outright basis.
    Almost no matter what you do, by the time everything is said-and-done, you're going to end up spending a lot more for these horns than they're really worth for a restoration.
    • Frank Bernier
      was 245 and 246 horns where only used for corvette ? or also other gm cars ?
        • 43221
        Frank-----
        As far as I can tell, they were Corvette-only. However, I would not rule out the possibility that they had some other application. Keep in mind that the main difference in all these PRODUCTION part number hors, aside from "note", was the attached bracket. The bracket configurations varied from car model-to-car model.
        • Jeffrey S.
          • May 31, 1988
          • 1882
          Frank:
          Also call Joe Perri at 312-307-1977. He also restores horns and has some for outyright sale.
          Jeff
