66 Stumbling update - NCRS Discussion Boards
66 Stumbling update
  • Gary S.
    • July 31, 1992
    • 1632
    66 Stumbling update
    Well, I put in a known good coil and ballast resistor from a neighbor's Corvette and took it out for a spin. Same stumbling and a nice back(after)fire through the tail pipe. I am going to pull the carb to see if any junk got stuck in a float or needle seat. In addition, I plan on pulling the distributor tomorrow to have it put on a machine to check it out.
  • Joe Fisher
    Re: 66 Stumbling update
    Before you pull the distributor, try a new ignition condenser. They have a habit of creating the problem you discribe. Joe
    • Gary S.
      • July 31, 1992
      • 1632
      Joe, put in a new condensor last week. I was trying to avoid all of the problem areas that I thought might be causing my stumbling. Gary
