1967 SIGNAL LIGHTS - NCRS Discussion Boards
1967 SIGNAL LIGHTS
  • ED #23560
    1967 SIGNAL LIGHTS
    MY DRIVER SIDE TURN SIGNAL LIGHTS BLINK MUCH SLOWER THAN MY PASSENGER SIDE TURN SIGNAL LIGHTS. I THINK THERE IS A SWITCH UNDER THE DASH THAT MY BE DEFECTIVE. AM I ON THE CORRECT PATH? IF SO IS THERE A PART#?? ECKLER'S???
  • Peter L.
    • May 31, 1983
    • 1930
    Re: 1967 SIGNAL LIGHTS
    Ed - Not sure what switch you are referring to, but if one side operates differently than the other, you might want to look at the bulbs, sockets, wiring, grounding, etc because there is only one turn signal flasher and unless the turn signal switch is broken both sides should flash at the same rate. Is there any problem with the blinking rate of the lamps when you operate the hazard flashers? Personally, I'd look for a poor ground. I'm sure you'll get some other input on this. Good luck. Pete
    • Kent K.
      • December 1, 1982
      • 1139
      Ed,
      Check your turn signal-parking lamp bulbs. Be sure they are per the owner's manual, otherwise, you'll get faster/slower blinking rates. Sorry, I'm not very adept at remembering the proper lamp numbers. I'm sure there are many posts in the archives regarding this subject.
      Please turn off your caps lock. With all capitals, it's like shouting.
      Kent Keech
      Kent
      NCM Founder - Member #718
      • Stephen L.
        • May 31, 1984
        • 3158
        Check your owners manual for proper bulb numbers.
