Identifying a '61/'62 body other than coves? - NCRS Discussion Boards
  • Paul B.
    • January 31, 2007
    • 313
    Hi,
    A friend of mine found a bare body tub with no frame or interior from either a '61 or '62.
    It had customizing done in the '70's or 80's, so we can't tell from the coves what year it is? He is looking to use it to build a street rod, any other way of identifying a body as a '61 or '62?
    Paul
  • William C.
    • May 31, 1975
    • 6037
    Re: Identifying a '61/'62 body other than coves?
    61 used a SS trim piece to outline the coves. The '62 body has a raised rib outlining that area. Doors as well as front fenders are different as the rib follows the front fender edge. This requires a separate small fibergalss section to be bonded to the front edge of the front wheelhouse opening that is not needed for a '61.
    Bill Clupper #618
    • Loren L.
      • April 30, 1976
      • 4104
      I forget what the sequence is (you're going
      to look it up anyway, aren't you?) but the location of the rear "popup" spring is a running change in location....
      • Loren L.
        • April 30, 1976
        • 4104
        Re: I forget what the sequence is (you're going
        for the trunk lid, so says the dope who refuses to proofread.......
        • Loren L.
          • April 30, 1976
          • 4104
          • Geoff C.
            • May 31, 1979
            • 1613
            Loren calm down; get a cocktail or 2 or 3 ... *NM*
