This is what I'm faced with on a '70 convertible (early production): 1--Wiper door opens when you use the under-dash bypass. 2--Wiper door does not open when you move the windshield wiper switch to low or high speed. 3--The wipers do not operate when you move the windshield wiper switch to low or high speed. 4--The wipers do operate if you hold down the wiper switch (as though you were using the washer).
The following have been investigated/checked: VACUUM COMPONENTS: 1--Vacuum reserve tank. OK 2--Manual vacuum valve (under dash). OK 3--Interlock switch (vacuum) in right plenum. Have not checked. 4--Vacuum control solenoid (under tach behind dash). Have not checked. ELECTRICAL COMPONENTS: 1--Wiper switch on dash. OK for washer. Assuming it's OK for lo-hi speeds since previous owner says he replaced it (have not verified that). May be noteworthy that the motor clicks once when you slide the wiper switch to lo; when you switch to off and switch to lo again, there is no click. 2--Wiper door limit switch. OK 3--Rotary service switch (under dash). OK 4--External relay (in front of floor console). Have not checked. 5--Vacuum control solenoid (under tach behind dash). Have not checked. 6--Windshield wiper fuse. OK 7--Fuse link (at horn relay). OK 8--Wiper motor relay (integral). Have not checked (motor assembly has NOT been removed from the car).
While check-out is not complete, it appears that those not checked should be OK since the wipers work if you hold down the wiper-washer switch. Maybe that's an incorrect assumption.
One of the previous owners (several years ago) replaced the wiper motor with a used one. The previous owner said, during his ownership, the wipers NEVER did anything other than what they are doing now...which is what I'm trying to fix. I'm really suspecting the wiper motor itself with its integral relay. I'm pausing to ask for help before I spend large dollars on potentially needless pasrts like a new wiper motor. I would prefer to really zero-in on the troublesome part(s) before ordering anything.
If you can point me to where on the web I could find some answers or if you have some from your own experience, I would be very appreciative!!
Thanks to anyone who can help or advise!!!
Don
Don
