freeze plug re-install question - NCRS Discussion Boards
  • Chris H.
    • April 1, 2000
    • 837
    Whoa, that's a tight fit. The new steel plug does not seem to want to go back in using a hammer. Are there any special tools that would make it easier? Would a brass one go in easier? Should I file the surface on the block to clean it up a little? What about the rubber expandable ones I've heard about? Any input is greatly appreciated as I'm off the road until I figure this one out.
    • 43221
    Re: freeze plug re-install question
    Chris-----
    I would not recommend taking a file to the freeze plug block hole, but I would recommend making sure that it is thoroughly clean. To do this, use Scotch-Brite or steel wool. You want to remove any corrosion or scale deposits, NOT metal.
    These plugs take a good wallop to install as they're thick metal and are designed to "swage" themselves in for a good seal and tight fit. One of the problems with installing them when the engine is in the car is getting enough of a swing on a hammer to apply the "persuasion" necessary. You might try a larger hammer, though. It will help make up for lack of swing room.
    I don't think that a brass plug would install much easier, but brass is "self-lubricating", so that might help. I'd use brass, anyway. The expandable type plugs will work, but they're, of course, totally non-original.
    • Jerry Clark
      Hammers
      Joe:
      I NEVER would have suspected that you would have a "Bigger Hammer" in your possession.
      jer
      • Big Block George
        hammer and a socket that fits into the plug.......
        and den whack the P--s out it. It will go in. Just don't miss and whack your finger.
        • Big Block Bowtie Everett
          Tidbit...
          Here is a tidbit I learned at a summer job doing refinery maintenance rebuilding pumps and installing bearings - put the freeze plug in your freezer overnight, get everything ready on the block, and when you are set, grab the frozen, contracted plug, run out to the car, and do it to it. The few thousandths contraction really helps out! George, you started this naming thing...
            • 43221
            Re: Hammers
            Jerry-----
            Well, I'm loathe to use it, but, I must admit, that I do keep one around for "emergencies". It still looks like new, though, so I have resorted to using it very sparingly.
            • Chris H.
              • April 1, 2000
              • 837
              Re: Tidbit...
              Big Bowtie, I had that exact thought about freezing the freeze plug last night as a lay in bed at 3am.
              • Big Block George
                Yeah, ain't it fun?
                All we gotta do is find someone named Vinnie and tag him with GUIDO.
                • Dave - NCRS#24235
                  Use a socket, extension & lead hammer
                  We senior mechanics put a short or long (depending on ease of use) extension backward into a socket, and drive that with a lead hammer (to save the extension and make driving easier). The extension saves fingers. I like the brass plug and frozen freeze plug ideas too. - Dave
