1975 Radio Problem... - NCRS Discussion Boards
  • Joe Hilton
    Hello everyone!!! I just joined the NRCS and just bought a 1975 convertible L82; my first corvette!!! Everything works except the clock and the right speaker...Any ideas on why my right channel speaker won't work? I checked the connections, look ok. My OHM meter says the speaker is getting juice. Left channel works fine. Doesn't matter if I have it in AM or FM, same result: no right speaker. I have a 1975 L82 vette with AM/FM Stereo Radio from Factory. When I turn the bottom dial that switches channel from left to right, no effect. Thank you in advance.
    Re: 1975 Radio Problem...
    How do you tell a speaker is 'getting juice' with an ohm meter?
    • A L.
      • January 1, 1992
      • 63
      Joe, You can switch speaker wires, if the speaker that wasn't working then works, the problem will be the radio or convector(outputs).
      AG
      • KEN BUTCHER
        Hi Joe, welcome to the club. I've got a 75' also, and I had the same problem with my left speaker, replaced it, no problem.
        Ken.
        • Bill S.
          • January 31, 2007
          • 396
          is it a stereo or mono. heres an old school way to test the speaker and harness. take a 9v battery and connect a wire to each post(+ and-) unplug the spkr lead at the radio and touch speaker wires (2) TO THE 2 battery wires. if the spk wourks it will make a popping sound telling you the wiring and spk is capable of producing sound. if the speaker and wires are good and it is a stereo you have a channel out but not usually it could be a cold solder conn. i have replaced speakers on delcos that have been out for years and they bounce right back most times. i have installed car radios for a living for 33 yrs and owned my own shop for 25+
