DELCO SHOCKS PLEASURIZER HEVAY DUTY 1 # P-2060 - NCRS Discussion Boards
  • VLADO MARJANOVIC
    DOES ANYONE KNOW WHAT THESE DELCO PLEASURIZER HEAVY DUTY SHOCKS FIT , ANY HELP WOULD BE AWESOME THANKS GUYS DELCO 1 # P-2060 ARE THEY CORRECT FOR 1968 CORVETTE ?? OR WHAT DO THE FIT IF NOT
    • 43209
    Re: DELCO SHOCKS PLEASURIZER HEVAY DUTY 1 # P-2060
    VLADO----
    Yes, the Delco P2060 are HD "Pleasurizers" applicable to the REAR shock for 63-82 Corvettes.
    • VLADO MARJANOVIC
      HOW CAN I TELL THE DATE ON THEM ?? OR IS THERE A DATE ??
        • 43209
        VLADO------
        There should be a date stamped on them somewhere on the lower end, near the Delco Products stamping. Usually, it will be a julian-type date code, but a few other formats were also used by Delco over the years. Report what you find and we may be able to interpret it.
        Also, what are the stamped-in GM part numbers you find in the same area? These should be a seven digit number, probably beginning with "4", "5", or "6".
        • VLADO MARJANOVIC
          LOOKS LIKE THERE IS A SET OF NUMBERS ON THE BOTTOM W3198260 AND AT THE VERY BOTTOM 069 72 CAN ANYONE TELL WHAT THE DATES ARE ON THESE SHOCKS THANKS
            Looks like the 69th day of 1972.
