Old tires ? - NCRS Discussion Boards
Old tires ?
  • Denny J.
    • November 1, 2000
    • 244
    Old tires ?
    How do you care for 34 year old tires.Store inside what can be put on them that judges will like.Or clean tire with simple green before judging.Keep them aired up or deflated.Something is needed to keep rubber soft.
  • Loren L.
    • April 30, 1976
    • 4104
    Forget trying to save them. You can
    perhaps extend the life by simply not having them on the car except for show display and otherwise keeping them out of ultraviolet rays, but there is NO MAGIC ANSWER.
    • Bill W.
      • March 1, 1980
      • 2000
      Re: Old tires ?
      Keep them inflated in a dark cool place until needed . No highway use . Soap and water to clean I wouldnt use any coatings .Bill
      • Harmon C.
        • August 31, 1994
        • 3228
        Re: Old tires ?
        Bill
        I lower the pressure in my Firestone 500's from the 20# max. that I use in them to 5#-10# when they are in storage. I would store them on the tread and keep carpet between them to protect the white from transfer of black onto the white letters. I had one blow out in storage before I started to lower the pressure. You may have better old tires as I think thease were the worst when new.
        Lyle
        Lyle
        • Twan B.
          • June 30, 2005
          • 207
          Re: Old tires ?
          It's better to give the tires "in storage" more pressure. When you give them less pressure the tire became little smaller so if you inflate them again for use the tires become little tears.
          I do this with my tires ( BF Goodrich 775x15 )every year when i store it over the winter and keep them out of the sun so the white strip will not fade away also use water and little soap for cleaning.
          Twan
          #44079
          • Bill W.
            • March 1, 1980
            • 2000
            Re: Old tires ?
            The tires I store are all non radial . I think they are a little tuffer . I have seen radials blow out while sitting ???
