1973 brake rotors - NCRS Discussion Boards
1973 brake rotors
  • John Pelkofer Jr
    1973 brake rotors
    Hello, Today a customer dropped off his 1973 conv. to have new front brake
    pads and calipers replaced. While resurfacing the rotors on the spindles, I
    noticed the rotors had the extra hole to adjust the parking brake. Further
    inspection identified them as rear rotors. Are these rotors interchangable?
    The owner states that they have been on the car for at least six years.
    Thank you in advance for any and all advice.
    • 43260
    Re: 1973 brake rotors
    John-----
    I believe that the rear rotors can be used on the front without any problems. However, if a front rotor is used for the rear (rotor only; not with hub, of course), then some additional machining has to be performed.
