67 springs - NCRS Discussion Boards
67 springs
  • Walt W.
    • November 1, 1998
    • 92
    67 springs
    I want to replace the front springs on my 67 L71 and wonder if anyone can recommend a good source and advise me on what details I should look for. It has F41 suspension.
    Thanks.
    Walt Weems
  • William C.
    • May 31, 1975
    • 6037
    Re: 67 springs
    Firstly on an F-41 car are you sure they are needed? The F-41 sits lower by design than the standard car. There is a measurement process in the service manual with specs for both, check that first, as the F-41's generally don't sag like the std springs.
    Bill Clupper #618
      • 43260
      Re: 67 springs
      walt and Bill-----
      I agree. I'd check for conformance to specs first. I really doubt that they need replacement.
      If, by chance, you are assessing the need based on a "rough ride", that's what you can expect with F-41.
      • Walt W.
        • November 1, 1998
        • 92
        Re: 67 springs
        My car sits low in the front and thats why I'm thinking of replacing the springs.
        • William C.
          • May 31, 1975
          • 6037
          Re: 67 springs
          Again, visually, or measured on a flat surface to the appropriate reference point on the front suspension. The F-41 is generally a little low in front. Chevk the service manual for the proper specs.
          Bill Clupper #618
