C2 chassis and engine detailing questions - NCRS Discussion Boards
+ More Options
Posts
  • Randy R.
    • March 1, 1983
    • 477
    I have a 67 L79 engine. Are there quidelines for the placement of the valve cover decals?
    Tripoli's Chassis Restoration Guide show a one inch chassis stencil for a 69 and a 7/8 in. stencil for a 57. The example for the 65 seems to be a little bit larger than the 3/4 in. stencil I received from Quanta. Is the Quanta stencil acceptable? The original gas tank stencil on my 67 was 1 in. high. The stencil I received from LIC was 3/4 in. high. I purchased a set of correct stencils at a hardware store. Just wondering if I have to do it again.
    Is the positraction differential tag supposed to loosely fit around the plug?
    Thank you,
    Randy
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: C2 chassis and engine detailing questions
    I had a local shop make both stencils for me to exact sizes, using one of the original stencil cutting machines, for my April 67 coupe.
    Gas tank stencil is 13/16 in high:
    ST.LOUIS
    3819506
    Frame stencil is 13/16 in high ( placed upside down and paint rolled on)
    303196-33-PC
    3900200-4-7/GC
    • Randy R.
      • March 1, 1983
      • 477
      Thank you for the reply. One of the few markings that survived on my chassis was the gas tank stencil. I obtained a set of stencil letters and numbers from a hardware store. The one inch height and the font matched, but I had to narrow the space between the letters to match the originals.
      Randy
