C3 (1969) carpet install question - NCRS Discussion Boards
+ More Options
Posts
  • Dave R.
    • October 8, 2007
    • 107
    Okay, I have the car all prepped for new carpet (waiting for it to arrive) and was wondering if anyone might be able to offer a tip on the best way to locate all of the various screw / bolt locations after the carpet has been layed down?
    I am talking about the screw holes for the T-Top straps, seat belt bolts; etc. I kept the original carpet to use as a guide, maybe that's the trick but, rather than rely solely on that method I thought I'd ask for suggestions.
  • Art A.
    • June 30, 1984
    • 834
    Re: C3 (1969) carpet install question
    David, After the carpet is installed, I use an old ice pick, heat it with a propane torch, and locate the treaded hole as best I can and push the ice pick thru the carpet cauterizing the carpet so the screw won't grab the carpet threads..................works for me.
    • Dave R.
      • October 8, 2007
      • 107
      Art, that sounds like a great tip. What method do you use to get in the ballpark of the threaded hole though? I don't want to "swiss cheese" my new carpet with cauterized holes.
      • Harmon C.
        • August 31, 1994
        • 3228
        Dave
        I hunt for the hole with a cold ice pick. For the larger holes I use a cheap pencil solder iron.
        Lyle
        Lyle
          Try probing with a cold awl or pin until you locate the point of interest and then come back with your hot tool. For those screw holes that go all the way through the body to the outside, consider using a hot soldering iron and entering the hole from the outside to the inside (PIF fasteners, Etc.).
          It's not 'rocket science'... The job was done by ordinary UAW workers!
          • Art A.
            • June 30, 1984
            • 834
            I use a dental tool(cold)........one that has the curved end broken off and is fairly straight.
            Art
            • Dick W.
              • 10483
              Don't forget to make a hole for the nine rubber plugs that hold the carpet in the front and on rear bulkhead. Many restored cars that I judge lack these plugs.
              Dick Whittington
              • Dave R.
                • October 8, 2007
                • 107
                Got the plugs; I was able to save the originals and will make it a point to reinstall them. Thanks for all of the suggestions; now where's that carpet?
                  • 3416
                  Your lucky to have your original plugs to reuse. Be sure to check back in the Archives for suggestions and methods to get them back in place without tearing them.
                  • Robert S.
                    • June 30, 2001
                    • 230
                    When I replaced the carpeting in my 74' coupe I used many of the techniques discussed plus one "other". I used this "other" technique for the fasteners for the left and right side chrome U bars that the tie down straps clip to. With the carpeting out of the car, I located the holes for the clip fasteners and cut the heads off of some hardware store fasteners and ground the ends down to a sharp point. I installed the fasteners in the holes with the sharp points facing up. I then installed the carpeting and pushed it down on the sharp points until they poked through the carpeting. I then removed the pointed fasteners one at a time and installed the U bars and the original, correct fasteners. It guarantees a perfect fit on one try with no extra holes in the carpeting.
                    Obviously this technique can be used at any fastener location but many do not require going to this trouble.
