Hood Catch - NCRS Discussion Boards
Hood Catch
  • Sam D.
    • May 31, 2006
    • 112
    Hood Catch
    Does any one know this. I asked earlier today? I believe because my car is a 63 build date the there is no black on the catch. Not sure about the spring? I also believe the bolts are black! I also think the Krylon will to.
    I have an early 64 car. build date of Nov. 63. It says in the NCRS judging Manual that the 63 catches are installed after blackout. Because my car was built in 63, does any part of my catch have to be painted black? The spring, the bolts, cable, or the flange on the catch it self? If so, and if I have to paint any part, will the Krylon 1613 Semi Flat work? Except the spring that says black Gloss? The springs are silver now. Not sure it there original, but if I had to guess I would say they are!
    Sam
    Re: Hood Catch
    The distinction lies with the model year and not the calendar year of production and has to do with whether the catches were installed at the time of engine compartment blackout or not. Also, there's a distinction between the source of body production (St. Louis vs. AO Smith body shops) with AO Smith cars typically having little/no blackout on the catches and interconnecting release cable. Give the JG text a re-read then see what body shop built your car (trim tag)...
      Re: Hood Catch
      Has to be a St. Louis body - A.O. Smith didn't start shipping '64 bodies until mid-January.
