Who has best C2 a arm bushings? - NCRS Discussion Boards
  • Stan E.
    • April 30, 1991
    • 383
    Who has upper and lower a arm bushings for a C2 that will pass flight judging?Thanks!!!
  • Phil P.
    • April 1, 2006
    • 409
    Re: Who has best C2 a arm bushings?
    i've installed moog and the complete kit from paragon---moog shows deterioration in less than a year with a car with 55 miles on it---the 2nd car was fitted with paragon bushings which are 30 days old installed so ? nothing yet---installation was the same---fit was the same---i would lok at cost being the deciding factor---good luck,phil
    • Rob A.
      • December 1, 1991
      • 2126
      gmpartsdirect.com part#401267
      try.....gmpartsdirect.com part#401267
        • 43222
        Re: gmpartsdirect.com part#401267
        Rob-----
        GM #401267 is not exactly correct for a C2, but it is 100% functional. This is the UPPER a-arm bushing and it lacks the "exposed rubber" on the inner end. Reproductions of the original style bushing are available from a variety of Corvette parts suppliers. The GM #401267 is correct for 1973-82 Corvettes.
        The LOWER bushing, GM #3714368, is exactly the same as original.
        • Greg L.
          • March 1, 2006
          • 2291
          Zip claims to have the correct uppers.
          • Dick W.
            • 10483
            Try Bair's www.bairs.com or Keen Parts www.keenparts.com
            Dick Whittington
            • John D.
              • December 1, 1979
              • 5507
              I was waiting for someone to say Bairs. I heard that Yogi had them made correctly now.
