64 Windshield Washer Reservoir Bracket - NCRS Discussion Boards
    Infrequent User
    • August 31, 1994
    • 25
    I need to rivet the windshield washer reservoir bracket onto the drivers side fender well. Can someone tell the location ie. 3" from top of fender and 4" from side of fender. thanks
  • Alan Drake
    Re: 64 Windshield Washer Reservoir Bracket
    Here is the location of the top inner (nearest to engine)rivet.
    6 1/8 inches from bottom gutter of fender (the step down area)measured along the inner fender
    10 7/8 from the outside fender bonding strip, again measured along the inner fender.
    Measured along the inner fender means I held the tape flat against the inner fender! the bracket appears to be parallel to the fender gutter line.
    This is for a Mar64 car only, can not say if others are the same, however I bet GM marked the panels to aid production, therefore the location must be close.
    have fun
      Infrequent User
      • August 31, 1994
      • 25
