67 427/435 Coupe Alignment. - NCRS Discussion Boards
  • Richard S.
    • November 1, 1994
    • 809
    Tomorrow morning I will have the Goodyear Regatta 2's installed and balanced. Size is 215/70/15 on 67 reproduction bolt ons. Could someone please advise the best alignment specs for a 4 wheel alignment. Thanks for the help.
    Re: 67 427/435 Coupe Alignment.
    Rick -
    For normal street operation:
    Front camber: zero
    Front caster: 2.5* positive with P/S, 1.5* with manual steering
    Front toe-in: zero-to-1/16" TOTAL toe-in with radial tires
    Rear camber: zero-to-1/2* negative
    Rear toe-in: 1/16" TOTAL toe-in, split equally (1/32" per side) across the thrust centerline; takes time and patience to do this one correctly.
    • Richard S.
      • November 1, 1994
      • 809
      Thanks John. *NM*
