C2-67 427-390 Carb gasket & heat shield - NCRS Discussion Boards
  • Stephen L.
    • May 31, 1984
    • 3158
    Is the order of assembly for the carb, gasket and metal heat baffle this:
    1) Intake manifold
    2) Gasket
    3) Metal baffle/heat shield
    4) Holley carb
    This is not covered in the judging manual. I was docked for this assembly order.
    The AIM looks like the items stack up this way.
    Re: C2-67 427-390 Carb gasket & heat shield
    Steve -
    Yes, that's the correct "stack"; whoever docked you for it needs to become more familiar with the design.
    • Stephen L.
      • May 31, 1984
      • 3158
      Thanks John.
        • 43221
        Steve-----
        There are LOTS of folks who think that the stainless heat shield goes on first, then the gasket. Every one of these folks is wrong. Period.
        • Clem Z.
          • January 1, 2006
          • 9427
          if you are not chasing points i would
          install a carb to intake gasket between the carb and the stainless plate because a lot of these older carbs have a warped throttle base plate and you will have a vacuum leak without the gasket
          • Ray G.
            • May 31, 1986
            • 1189
            Hello;
            Use a very thin coat of sealer between the carb & heat shield.
            Assemble the the components. Push down w/ hand pressure.(don't bolt together)
            Take it back apart to check for a good seal between carb and heat shield.
            Hope that helps.
            Ray
            I hope you dance
            • Clem Z.
              • January 1, 2006
              • 9427
              DO NOT use RTV as the sealer
              because gasoline will dissolve it
