Need pic of C1 underhood blackout masking - NCRS Discussion Boards
  • Paul B.
    • January 31, 2007
    • 313
    Hi,
    Does anyone have a pic of the correct masking of the underhood trim for my '62?
    I am having some paintwork done on my car and I need picture or two to show the body shop how it should be done.
    Paul
  • Terry D.
    • May 31, 1987
    • 2691
    Re: Need pic of C1 underhood blackout masking
    Paul
    The Judging manual says the "paint was applied to the underside of the hood panel lip, about 1 inch wide, stopping at start of radius of underside reinforcement panel. The paint margin line was achieved with a paint mask and may be slightly irregular and is not a criso line. Paint margin extends forward at front of car; does not wrap around forward lip of hood panel."
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11323
      Paul, Don't know if it'll help, but here are some shots I just took of my early, very rough 62 #483. There is heavy overspary on the 1" horizontal lip on both sides. The prior owner may have painted the 1" lip white. He spray painted the entire car with spray bombs over the last 35 years, so he may have decided to touch up the entire horizontal area on both sides. I can see black under the overspray. I used a pocket knife and scraped the white away to see it(pic#1 & 2).
      Also note the last pic. As I was looking around I saw this. Must be the "toolkit holder", attached to a relocated aftermarket horn.:-)
      I'm glad folks are asking these questions now. Makes me take more pictures!
      • Paul B.
        • January 31, 2007
        • 313
        Thanks for the responses guys. I have the manual, but I would like to see how the forward most portion of the hood is done? I understand that the black does not go around the front, but I would like a good picture of it?
        Also, if you don't use tape to cut the lines, how do you do it so that it looks correct?
        Paul
        • Rainer S.
          • May 31, 2003
          • 468
          Rich, how do you list the numerous URL's ? I know, how to do it with one, but several ? I use imageshack as a host...
          Rainer
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11323
            Rainer,
            I don't bother with the "Optional Image URL:" box in the post display, I just copy/paste the url links of my files into the post I write up.
            • Rainer S.
              • May 31, 2003
              • 468
              What a good idea! I will try that, next time I want to post more than (1) pic.
              Rainer
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11323
                Paul, Ill try to get one tomorrow, but it's tough to see in there with the grille on. I'll try and let you know.
                • Richard M.
                  Super Moderator
                  • August 31, 1988
                  • 11323
                  Paul,
                  I finally looked at the undrside of my 62 hood. It is bare fiberglass, not painted white or black. I tried to photograph, using a mirror, but could not get a good shot. I was surprised it wasn't painted.
