1967 starter - NCRS Discussion Boards
1967 starter
  • Brian #46951
    1967 starter
    Please take a look. Are the colors and metals correct for this starter
  • Brian #46951
    Re: 1967 starter
    Here is a second photo of the starter with date code and manufacturer. Appears correct per the Tech Manual. Your thoughts. Also, if someone can tell me how to post two photos in one post, please let me know. Do you seperate the photos with a symbol ( ; or : or , etc...)
    • Stephen L.
      • May 31, 1984
      • 3158
      Re: 1967 starter
      Starter and solenoid should be all black....
      To post multiple photos just place the entire photo address in the body of the message....... rather than the "bar" at the bottom.
      • David K.
        • August 31, 2002
        • 62
        Re: 1967 starter
        Per the '67 tech manual the starter body is painted semi-gloss black and the front plate is natural steel. The solenoid appears correct as it is described as cad or zinc plated metal with a dark brown Bakelite front end.
        • Kevin M.
          • November 1, 2000
          • 1271
          Re: 1967 starter
          Stamp looks good to.
          Kevin
          • Ray G.
            • May 31, 1986
            • 1189
            Re: '67 starter. through bolt stud for bracket? *NM*
            I hope you dance
            • Brian #46951
              Ray: Sorry, but I don't understand your question/comment. Can you expand on your thoughts.
              • Ray G.
                • May 31, 1986
                • 1189
                Hello;
                Your picture shows what appears to be the hex end of the top through bolt holding the starter together.
                The bolt should have a stud on which the starter bracket, to the engine block, fastens.
                Hope that helps.
                Ray
                I hope you dance
