66 front rotors? - NCRS Discussion Boards
66 front rotors?
  • Robert Roach
    66 front rotors?
    On the car I'm restoring the front rotors are riveted to the baer housing. The rotors that I ordered is just the rotors. What do I nee to do to make it original?
    • 43259
    Re: 66 front rotors?
    Robert-----
    If you just want to install the rotors, then you need to drill out the original rotor-attaching rivets to remove the existing rotors. Then, you install the new rotors, install the wheel lug nuts torqued to spec, and check runout. If it's ok, you're done, except for re-installing the wheels and lug nuts. The wheel and lug nuts will retain the rotors; the original rivets are not necessary.
    If you want to retain complete, original configuration, then you'll need to send the hubs and new rotors off to someplace like Bair's in Linesville, PA. They can install the new rotors you have, insure proper runout, and re-rivet the new rotors to the hubs. There's really no practical way to do the re-riveting yourself.
