C1 speedometer face restoration - NCRS Discussion Boards
  • Charles C.
    • May 31, 1978
    • 65
    Who can you recommend to restore/repaint the speedometer face and rebuilt the speedometer for a '61 Vette. Is the odometer reproduced or should I use the original odometer (even though the numbers are cracked).
    Thanks.
  • Terry D.
    • May 31, 1987
    • 2697
    Re: C1 speedometer face restoration
    I've used Roger Scott several times and would use again, 561-691-2905. Let him decide if odometer can be saved.
    • David B.
      • July 31, 2004
      • 330
      The odometer is repro'd. But, the "9" is slightly different. Available from Zip and others.
      I had Roger do my tach - very good work.
      Dave
      Dave, 1969 427, 1957
      Previous: 1968 427, 1973 454
      • Mike E.
        • February 28, 1975
        • 5141
        Repros I've seen of the odometer were close, but no cigar--the white part of the numbers is slightly thinner than the originals.
        GM Passenger cars in the boneyards from that vintage have identical odometers.
