change to T.I. Ignition - NCRS Discussion Boards
  • Dave Stafford
    I'm thinking to change out standard (but not #'s correct) point ignition system to #'s correct '67 T.I. Any suggestions on this? Approximate cost and things to watch out for? This will go into an L68 '67. As always, thanks in advance.
    • 43231
    Re: change to T.I. Ignition
    Dave-----
    This is a pretty straight-forward, "bolt-on" conversion. You will require the following parts, though, all of which are GM-discontinued:
    TI distributor
    TI ignition coil
    TI amplifier
    TI auxilliary wiring harness
    I have not provided part numbers since a variety of part numbers could be used to create a FUNCTIONAL system. If you're after strict originality, specific part numbers would apply. In any event, for a set of new/rebuilt components to create a FUNCTIONAL system, expect to pay about $1,000+.
