Spraying Color - NCRS Discussion Boards
Spraying Color
  • Donald T.
    • September 30, 2002
    • 1319
    Spraying Color
    Can a vacation get any better than spraying the final coats of Rally Red lacquer? Who needs palm trees and drinks with umbrellas! This might be the year I actually finish this project, but don't hold your breath.
  • Stephen L.
    • May 31, 1984
    • 3158
    Re: Spraying Color
    Glad to see that you are working on your own restoration at home. Great feeling of accomplishment when its done!!!!
    • Michael L.
      • July 31, 2005
      • 562
      Re: Spraying Color
      Don, I'm assuming an HVLP gun was used as overspray seems minimal. What kind of compressor, gun and paint did you use? I have a Polo White paint job coming up and I really want to spray my own as well! Also, what did you use as sealer, primer?
      Hope to see finished product!
      • Donald T.
        • 1319
        Re: Spraying Color
        Mike,
        Yes, the gun is an HVLP. It's a Devilbiss Finish Line 2. I believe it has since been replaced with the FL3. The compressor is from Lowes and is 30 gallon rated at 5.7 SCFM at 90 PSI with a cast iron pump, which is more than adequate. I used PPG DPLF for a sealer; followed by Kondar for block sanding; followed again by DPLF; followed by Duracryl. Good luck with your project!
        Lots of color sanding and buffing to look forward to now!
        • Mike G.
          • January 1, 1991
          • 418
          Patience
          Don: I'm just one step behind you on my '65 ermine white roadster --getting ready to shoot Duracryl topcoats. Even using the same materials: DPLF, Polyprime catalyzed hi-build, Kondar DZ lacquer primer, DPLF over-reduced for sealer, and now the DDL acrylic lacquer. Also the same HVLP Finishline gun!
          To perfect my technique,I used the rear valence and the decklid underside as test pieces. So far so good, they are finished and are way too nice.
          Here's the suggestion I would offer you or anyone else shooting lacquer: wait a MONTH before you start with the 1000/1500/2000 color sanding. It's amazing how this material continues to shrink as it gives up the entrapped solvents!! Also, the more fully cured it is -the better results you'll get in compounding & polishing.
          • Gerard F.
            • June 30, 2004
            • 3806
            Fantastic! Don
            That's what I want to do some day to my 67.
            Jerry Fuccillo
            #42179
            Jerry Fuccillo
            • Randy R.
              • April 2, 2007
              • 39
              Re: Spraying Color
              Don--
              How many coats of the lacquer did you go with? Looks Great.
              • Donald T.
                • 1319
                Re: Spraying Color
                Randy,
                12 coats of lacquer total. The initial 6 coats were not enough coverage after color sanding, so I sprayed another 6 coats. I should now have plenty for color sanding and buffing.
                • Mike G.
                  • January 1, 1991
                  • 418
                  2 gallons?
                  Don: did you get 12 coats from 2 gallons of DDL? Mike
                  • Donald T.
                    • 1319
                    Re: 2 gallons?
                    Mike,
                    Yes, I used 2 gallons of duracryl with some left over for touch ups.
                    • Randy R.
                      • April 2, 2007
                      • 39
                      Re: 2 gallons?
                      Don--
                      What paint to thinner ratio did you use?
                      • Donald T.
                        • 1319
                        Re: 2 gallons?
                        The Duracryl was 1:1.5 as recommended by PPG.
                          • 15674
                          Re: 2 gallons?
                          When you refer to coats do you mean double coats - i.e overlapping the previous pass by 50 percent?
                          • Donald T.
                            • 1319
                            Re: 2 gallons?
                            Yes, overlapping 50% with each coat. Also applied extra coverage for all of the peak areas.
                            • Mike G.
                              • January 1, 1991
                              • 418
                              Six complete coats?
                              Don: are you describing a single application with the recommended 50% overlap as TWO coats? If so, I now understand where the 12 coats from 2 gallons of material becomes possible. It's really six complete coats, as most would describe it. Good idea on the extra material over the peaks. I plan to mask the peaks with 1/4" green tape when I compound it. Even seen some of the pros use this insurance.
