I'm overhauling the seat back release components on my 1967 Coupe. When assembled, the component parts reside under a plastic cover that is sandwiched between the seat padding/springs/etc. and seat release. I'm missing the cover on one side. Can the seat be reassembled without the cover with a high level of confidence the seat release won't come apart? If not, any ideas? I have not found the cover available.
I have also found that the Seat Back Lever Fork pivot broken. This part is pressed into the seat frame and peened over at one end. I have drilled this out. Is the Seat Back Lever Pivot Screw currently available from most parts sources the correct replacement part?
Lee
Lee
