I just replaced the front calipers and pads on my 67. Also replaced all wheel studs because some were broken or damaged. Now, when I bolt the wheel back on, it won't turn. I took the wheel back off and the rotor turns just fine, so I put a couple of lug nuts on and drew them up tight............rotor won't turn again. Rotors are fairly new replacements, had no problems before. Has anyone ever experienced this problem or do you have any suggestions?
Rex
Rex
