C2 Interior Door Lock Knob Removal - NCRS Discussion Boards
  • Dave K.
    • November 1, 1999
    • 952
    I've got to pull the driver's side door panel to inspect the window track and was wondering if there was a trick to remove the door lock knob without damaging the vinyl panel. The lock knob is recessed and it is hard to get a tool behind it to release the clip that locks it to the lock shaft.
    Dave K.
  • Alan Drake
    Re: C2 Interior Door Lock Knob Removal
    There are special tools for that which do all the handles, however I believe a very short time ago somebody posted a method using cloth as a pull tool. Do a search - not sure of what words to search for, sorry.
    • Mike G.
      • January 1, 1991
      • 418
      Best method I've found is using a small hooked pick to grab the omega clip and pull it back. Use a little masking tape to protect the vinyl while you're fussin' & cussin' and trying to hook that pesky clip.
      Always wished someone would make a special omega clip with a loop that facilitated hooking it!
      • Dave K.
        • November 1, 1999
        • 952
        Thanks to all- found a lot of info on this subject in the archives under C2 door panel tool and removal.
        Dave K.
