Positrac carrier identification - NCRS Discussion Boards
  • Verle R.
    • March 1, 1989
    • 1163
    Can someone identify positrac carrier EDB32212?
    Thank you,
    Verle
  • Terry D.
    • May 31, 1987
    • 2691
    Re: Positrac carrier identification
    Where did you find those numbers?
    • Verle R.
      • March 1, 1989
      • 1163
      Casting numbers on the carrier.
      Thank you,
      Verle
      • Wayne M.
        • March 1, 1980
        • 6414
        Verle, I've been scratching my head .....
        on your carrier cast #. I can't positively identify it as it contains bits of a few that I CAN find in my parts books.
        Viz. the "EDB" is usually an Eaton designation (ie EDB_30175 for 4-series posi on '65 to '68(?) Corvettes. EDB_30117 for 3-series, same period. Then in '69-up(?) the Corvette carrier changed to "big window" type ED_32297 (3-series) and EDB_32298 (4-series).
        Also, in the P&A30 parts books, there's a Dana carrier '57-62 Corvette Posi w/4.11 or 4.56 with numbers 22212X (same numbers except for the first of yours and the X at the end).
        I realize this might not help, but it might point in the right direction
        Wayne
        • Verle R.
          • March 1, 1989
          • 1163
          Re: Verle, I've been scratching my head .....
          Wayne,
          Thank you for the response. I have asked several different sources and no one can come up with the answer.
          I appreciate your efforts.
          Verle
