C2 teak steering wheel - NCRS Discussion Boards
  • Larry S.
    • March 11, 2007
    • 457
    I just received a reproduction teak steering for my '67 (I know that's not authentic, but I don't like plastic; I'll keep the plastic wheel stored away.) The finish on the reproduction wood is very dull. It seems I remember that the finish on the teak wheel on my departed '66 (original equipment) was at least satiny, if not glossy. Should I polyurethane it? Satin or glossy? Or is my memory bad? Thank you.
  • Dick W.
    • 10483
    Re: C2 teak steering wheel
    They are slightly duller than satin. Hard to qualify the % of gloss.
    Dick Whittington
    • Larry S.
      • March 11, 2007
      • 457
      Thanks, Dick. That's what this one is--slightly duller than satin--so I guess I'll leave it the way ir is. Seems a shame not to bring out the beauty of the wood. Thanks again for the advice.
        Per Eric Freeman (yesterday):
        "The teak is sealed with clear shellac, then topcoated with clear satin polyurethane. If finish is worn, hand-sand the worn area with extra-fine sandpaper, wipe on some clear shellac, rub the dried shellac with 3M Scotchbrite pad, then spray clear satin polyurethane from a spray can over the repaired area."
