Carbs - NCRS Discussion Boards
Carbs
  • Chuck R.
    • April 30, 1999
    • 1434
    Carbs
    What was the cfm rating for the 327/300hp and the 350/350hp? Just curious,
    Chuck
  • David D.
    • 330
    585 cfm *NM*
      • 43203
      Re: Carbs
      Chuck-----
      If you really meant 327/350 hp, then Dave's answer is correct. However, if you actually meant 350/350 hp (i.e. 1969-70 L-46) then the rating for the Rochester Q-Jet used for those applications was about 800 CFM.
      • Chuck R.
        • April 30, 1999
        • 1434
        Re: Thanks to you both but...........
        I was wondering what the cfm spread between my 327/300 and the 350/350 was with the transition from 1968 to 1969 small blocks.
        Do you also have the compression ratios at hand? I thinking the 350/350 had 11:1 or 12:1 My 327/300 I don't know.
        Thanks for getting back to me,
        Chuck
        • William C.
          • May 31, 1975
          • 6037
          68-69 Carb CFM was the same from '68 Quadrajet to '69 version, regardless of HP rating. The Advertised CR for the 350hp was 11.0 to one in both years, and the 300hp was 10.25 in '69 and 10.0 in '68.
          Bill Clupper #618
          • Chuck R.
            • April 30, 1999
            • 1434
            Re: Thanks Bill *NM*
